VMWare Fusion2 #404518 12/24/08 04:19 AM
DLC Offline OP
I invented modding!
I invented modding!
Anyone tried this ?
Any tips or warnings.
What do you do if you have XP under Boot Camp and want to install Fusion2?
Will the instal make the XP open under Fusion? (instead of Boot Camp?)
Or do I need to remove XP , install Fusion and then reinstall XP ??
ONLY reason I'm doing this is I have a Windows only stock analysis program from TD Ameritrade that I want to try out.
Thanks! wink
David (OFI)
Re: VMWare Fusion2 [Re: DLC] #404578 12/24/08 07:48 PM
zwei Offline
soporific
soporific
Boot Camp and Fusion are completely separate if you want them to be. Unless you want to use the boot camp partition under fusion that is. Fusion can boot using your Boot camp partition. I used it that way for a long time. I have since reinstalled XP into a Fusion disk image. Up to you which way you want to go.
Re: VMWare Fusion2 [Re: zwei] #404583 12/24/08 10:11 PM
DLC Offline OP
I invented modding!
I invented modding!
Thanks, Zwei !! I just want to keep it simple and I'm not gaming so I don't need light speed, just good compatibility.
David (OFI)
Re: VMWare Fusion2 [Re: DLC] #404729 12/27/08 04:11 AM
MacGizmo Offline
What?
What?
If that's all you need, why not just use VirtualBox? It's free and works extremely well. It doesn't have the bells & whistles of Fusion, but it runs Windows perfectly. I've been using it with Windows XP for several months now with no problems at all.
The Graphic Mac - Tips, reviews & more on all things OSX & graphic design.
Re: VMWare Fusion2 [Re: MacGizmo] #404931 12/29/08 02:32 AM
MacGizmo Offline
What?
What?
Fusion now just $15 at MacMall
Re: VMWare Fusion2 [Re: MacGizmo] #405341 12/31/08 12:01 PM
DLC Offline OP
I invented modding!
I invented modding!
Bummer !! I paid $30 !! blush
I want a refund !! laugh
David (OFI)
