I'm gona post this in here as a record so if we ever need to reference it...
In order to preserve VisualHub (or AudialHub) if you need to switch computers, you need to back up two things:
1: The VisualHub (or AudialHub) app itself 2: The conversion engine
To back up the conversion engine, Copy the folder at: /Library/Application Support/Techspansion
...for good measure, you can also back up your Preferences file, containing your registration info in case you lose the original purchase e-mail. It's at: /Users/yourname/Library/Preferences/com.techspansion.visualhub.plist ...or for AudialHub: /Users/yourname/Library/Preferences/com.techspansion.audialhub.plist
As far as I can tell, the two programs will continue to work in Snow Leopard, but I obviously can't predict the future or what Apple will do in it, though.
Thanks for enjoying Techspansion's software. It's been an amazing journey, and I'm sorry I won't be making it with you anymore.
MPEG Streamclip is a powerful high-quality video converter, player, editor for MPEG, QuickTime, transport streams, iPod. And now it is a DivX editor and encoding machine, and even a stream and YouTube downloader.
You can use MPEG Streamclip to: open most movie formats including MPEG files or transport streams; play them at full screen; edit them with Cut, Copy, Paste, and Trim; set In/Out points and convert them into muxed or demuxed files, or export them to QuickTime, AVI, DV and MPEG-4 files with more than professional quality, so you can easily import them in Final Cut Pro, DVD Studio Pro, Toast 6, 7, 8, and use them with many other applications or devices. Supported input formats: MPEG, VOB, PS, M2P, MOD, VRO, DAT, MOV, DV, AVI, MP4, TS, M2T, MMV, REC, VID, AUD, AVR, VDR, PVR, TP0, TOD, M2V, M1V, MPV, AIFF, M1A, MP2, MPA, AC3, ...
OK. I got it. And it's pretty cool. I can see my nearly 4000 mp3s and all of my pics in iPhoto. I spent an hour lounging on the sofa last night, just cruising YouTube. Same compressed vids, but on a 52" screen. Sweet. I haven't rented a movie yet... but I can see hundreds? of previews and they load quickly. I can barely see any compression on the previews, so I am assuming the movie will retain the same quality.
#430651 - 06/02/0910:40 AMRe: Apple TV questions
[Re: MrB]
QT movie trailers are 480p HD at a minimum. Of course, 720p and 1080p are available depending on your bandwidth and hardware. My gone but not forgotten G4 could do 720p on a good day, but 480p performed better on that old machine. My Mac Mini can handle 1080p when I let it download completely before playing and 720p streaming.
I wish. Just picked one up, the max is 720p, and even that is at a 24fps maximum (plus better keep data rates below about 5Mbs).
I knew this (mostly) going in and its fine for most movies I watch. I don't even own a Blu-ray player. The crappy problem is that I have a 1080p/30fps camcorder. So, I have to dump pixels all the way down to 960x540 to keep the fps at 30 and have it work with the ATV. Poo.
Still, a very cool device and as the price is down around an even $200 I'm not complaining too loudly.
