Anyone else noticing this? When I'm using the wide-screen keyboard for data entry (in Safari, or Wide Email as in the example below) if I hit the '1' key, the flag stays stuck up on the screen until I hit another key:
*edit* so - the forum doesn't accept PNG images? *edit edit* it does if I type in the right folder name first ....
Hold down the 'sleep' button on top and immediately click the Home button - takes a screenshot, default seems to be png (which is a nuisance because the image transfer app I'm using only recognises jpgs at the moment!)
The image transfer app I'm using (or trying, anyeway) is called PhotoSync - you connect over wifi and get to browse your Photos folder in your browser, and download from there, but only jpgs. I'm probably going to look for another instead...
