#401250 - 12/06/0804:57 AMRemember Michael Rennie as Klaatu?
He waves his hands in front of a complex panel, and the machine beneath comes to life. He waves his hands some more, and the machine does computer-like stuff. Well, take a gander at this. Can Gort be far behind?!
#401260 - 12/06/0806:37 AMRe: Remember Michael Rennie as Klaatu?
[Re: yoyo52]
carp
Dino's are Babe magnets
Loc: Hawaii
Seems to me that "MS" had this 25,000 touch table idea "basic large iPhone" - Then CNN took that away with their Magic Wall and Magic Table , witched worked some times but they are using PCs so they are forgiven . Bum luck sorta thing , an end run back to MS.
Mmm... the review I saw started with 'If you liked The War of the Worlds, you'll love this...' and I gave up at that point
The original is so atmospheric; it sounds as though this time round, they've made do with special effects instead. I might go and see it though - I'll let you know if I do.
Meanwhile...
Edited by padmavyuha (12/12/0808:53 PM)
