Some intractable problems always happen in our life. For examples, Some PC users want to share WMV files to their friends, but friends has Mac computers; I want to convert WMV to MP4, convert WMV to MOV, convert WMV to WAV, etc on my MacBook, but can't find an easy tool to finish it, etc. Now I will recommend a Mac WMV Converter to solve all your WMV problems.
Click the "Add video" button to import your WMV video, this Total Media Converter for Mac support batch conversion, so you can import multiple files at a time.
Step2. Convert WMV to MP4, WMV to MOV, WMV to AVI/MPEG/MP3/AAC/etc
Check the files you want to convert, and then click the "Settings" button to select output formats. There are some categories such as common video, common audio, iPod, iPhone, PSP, or you can customize the formats according to your need.
After the above steps, you can click the "Start" button to finish the conversion.
Tips: 1. Open the "Edit" section to edit your WMV file, you can trim a part of WMV file, or cut off the black edges of your video, or add watermark to your video for sharing.
2. If you want to join some WMV files to one file for playback on your iPod, iPhone, PSP, or other portable devices, you can check "Merge into one file" on the main interface of this software.
4. If you have other video formats, such as MKV, TS,TP, MTS, M2TS, TRP, FLV, MP4, MOV, AVI, Mod, ASF, etc, Total Media Converter also can help you convert them to your need formats.
