#396508 - 11/13/0802:25 PMRe: Little icon next to username
[Re: MicMeister]
Sven is right. If you are on stealth mode, the icon doesn't change, at least for you--apparently others do see the change. I just shifted so I'm no longer stealthy and see my little emoticon, which I've changed from to
