#396428 - 11/13/0811:24 AMRe: Little icon next to username
[Re: John Rougeux]
MicMeister
Le Skibum & Pixelsmith
Now it's yellow, Neil.
Uhmmm, did you go to Photoshop or other app and paste ([Ctrl+V] in Windows ;)) it from the clipboard, John? The thing with Windows screenshot is, it doesn't make it into a file right away, like Mac does. Instead, it gets copied onto the clipboard and you have to paste it from there.
#396445 - 11/13/0811:39 AMRe: Little icon next to username
[Re: John Rougeux]
Phosphor
An unreasonable man
Loc: Lancaster PA USA
I'm with you, John.
I don't care about that icon, and it could go away AFAIC. If I wanna find out who's online (and I usually don't care either way), I'll just look at the "Who's Online?" list at the top.
