OK. I have a new 52" Sony HDTV.... it rocks.<br>I finally bought an DVI to HDMI cable and an optical-mini to optical cable and hooked up my 15" MBP that I bought several months back. My brother gave me a slew of movies that he had on disk. Mostly AVI files. NVM where they came from.... [rollseyes]<br>I was pleasantly surprised to see Front Row in action in my living room on my new TV.<br>My photos look great! and I was tickled to see that the AVI movies in my movie folder played fine. I would not have thought that AVI files would be played by Apples Front Row.<br>But they did. Is it using some other app to play them through Front Row?<br><br>I see Apple TV refurbs at Apple... 160 GB for 279. I have a Airport set up with N network and it cables.<br>It seems to be a lot easier and cleaner to use a small Apple TV that stays in myEntertainment center than schlepping my MBP back/forth.<br><br>Now my question. Can I see that Apple TV from my desktop? Can I drag/drop AVI files to the ATV? <br>That would be sweet and I would get one if so. Can I put photos on it instead of streaming from my computers?<br>If it's gonna be Apple-only content then I'll pass.<br><br><br>[image][/image]
I have the 80GB one and I only put photos on it, everything else is streamed. I would save the money and get the smaller one.<br><br>You manage content on the AppleTV via iTunes. It doesn't mount on your desktop. I use Visual Hub to convert AVI movies to MP4 for AppleTV, but I think that you can install something on your AppleTV to play any files.<br><br><br><br>my photos
#392495 - 11/01/0811:51 AMRe: Apple TV questions
[Re: NucleusG4]
Nagromme
Loc: USA
Front Row uses QuickTime, which supports AVI (to a limited extent anyway). So I guess Front Row plays anything QuickTime can play, unlike iPods/AppleTV which only support certain formats.<br><br>nagr[color:red]o</font color=red>mme<br><br>STROGG: Change We Can Believe In<br>TeamMacOSX.com | MacClan.net
I use Visual Hub to convert AVI movies to MP4 for AppleTV<br><br>How do you get it into iTunes after that? Just drop in a specific iTunes folder?<br><br>[image][/image]
There's an actual button that says "Add to iTunes".<br><br>Unfortunately, the creator of Visual Hub has decided not to do it anymore. Handbrake may be able to do it.<br><br>[color:white]I'm also known as OSXaddict</font color=white><br>
[white]I'm also known as OSXaddict[/white]<br>
You just need something to convert it, and I *think* handbrake can do this. As for iTunes seeing it, once it's converted, you can just drag/drop it into iTunes.
