<br>Feels snappier, the battery life appears to be better as well, and all of the apps I had installed, continue to be working.<br>That was an easy update .... <br><br><br><br><br>
"Humor ist, wenn man trotzdem lacht" (Humour means laughing despite of it)
#382010 - 09/12/0801:49 PMRe: 2.1 is okay!
[Re: eckhard]
Nagromme
Loc: USA
I'm letting it do its looooong backup before the update (hopefully the last of those!) and then I will find out for myself!<br><br>If nothing else, I can look forward to the new apps I've downloaded but never installed because I was waiting for 2.1.<br><br>nagr[color:red]o</font color=red>mme<br><br>I require stroyent!<br>TeamMacOSX.com | MacClan.net
#382011 - 09/12/0804:45 PMRe: 2.1 is okay!
[Re: Nagromme]
Nagromme
Loc: USA
No problems so far. Backups are now quick.<br><br>But FlyCast won't launch for me. It's not the same old app-quitting, it just sits on black. I think it's a problem some have been having with that app from the start though. I'll await an update.<br><br>nagr[color:red]o</font color=red>mme<br><br>I require stroyent!<br>TeamMacOSX.com | MacClan.net
<br>Didn't notice the Genius, did see the increased track information.<br><br>This, however: "Apple also made a handful of security updates, including preventing applications from viewing each other’s data" might just mean that the dream of a 3rd Party Finder has been laid to rest.<br><br>FlyCast, by the way, works fine.<br>Now I'm off to do some errands .... chance to see of battery life has been improved.<br><br><br>ps: after one of our last exchanges, I got the Sennheiser PX100 as a companion to the PX200 (the "closed" system). As I had recalled, the PX100 is much freer sounding with a nicer tonal balance. ..... Being so small and foldable, those make excellent real listening phones for the iPhone.<br><br><br><br><br><br><br>
Nagromme
Loc: USA
I was just listing on my PX-100s to music that I bought after finding it via Pandora I've had them for years and they are still like new, from the tiny hinges to the tiny wires. They've been abused heavily in pockets and bags and have met the challenge.<br><br>FlyCast works for me too... just not all the time. Maybe they're struggling with a surge of usage. So far, I'll keep AOL and FlyCast around but Pandora is where I'll turn first if I want music other than my own.<br><br>I think I'd prefer a FIRST party Finder anyway, but I can verify that Air Sharing works fine in 2.1. Very useful! If I'm on the go and someone has a file to give me, I just hit the button in AS that displays my current WiFI address, then tell that to the person. They can mount the Public folder and give (or take) whatever is needed! AS even has instructions built in to help mount a new server on Mac, Windows or Linux. Thanks for the heads-up on that app.<br><br>I don't see why apps couldn't use that same method to share files with each other: WebDAV served back to the host machine. If various apps could edit and save docs in Air Sharing's file area that would be awesome.<br><br>Mini-tip-of-the-day: if you're browsing through your media library AND playing music at the same time, you may want to skip or pause--but hitting Now Playing to do so takes you away from where you were browsing. Solution: double-click the home button, which works even while you're already in the iPod app. You can then control playback without leaving the screen you're on.<br><br>nagr[color:red]o</font color=red>mme<br><br>I require stroyent!<br>TeamMacOSX.com | MacClan.net
