So...now my Finder won't run after restarting (updated QT).<br><br>Any help? I can't access anything except my Applications Folder. I don't have Leopard here, but will have it in the morning.<br><br><br><br>my photos
#381436 - 09/09/0810:42 PMRe: Finder not working
[Re: OSXaddict]
Nagromme
Loc: USA
Get Yasu from VersionTracker. It runs all the usual (and unusual) troubleshooting and maintenance steps for you so you don't have to waste your time on them.<br><br>I suggest:<br><br>1. Reboot with Shift held (does a disk repair without needing the DVD, and enters Safe Boot mode).<br><br>2. Run Yasu with all boxes checked EXCEPT don't bother clearing your logs (they might be useful), your cookies, or your bookmark icons. Some also say not to clear your system caches unless you have to. Your call.<br><br>3. Let it reboot the machine when done (which will exit Safe Boot).<br><br>You may find your problems are gone and you never need to know or care what caused them.<br><br>nagr[color:red]o</font color=red>mme<br><br>I require stroyent!<br>TeamMacOSX.com | MacClan.net
#381437 - 09/09/0811:02 PMRe: Finder not working
[Re: OSXaddict]
MikeSellers
I'm not into titles
Loc: Atlanta, GA
You could try re-applying the latest OS update. If it's not possible to run it, do you have another computer you can attach it to via Firewire Target Disk mode?<br><br>
#381440 - 09/10/0802:22 AMRe: Finder not working
[Re: OSXaddict]
Nagromme
Loc: USA
Can you use Spotlight to launch stuff? Search for "yasu"?<br><br>nagr[color:red]o</font color=red>mme<br><br>I require stroyent!<br>TeamMacOSX.com | MacClan.net
