"No, but if I do, then what?"<br><br><br>When you boot to safe mode OS X repairs some things. It's possible Disk Utility would then mount the drive.<br><br>
The buttons were clickable before though, right? Maybe you need to reboot, seriously. Sometimes it needs to load the driver again or something for programs to be able access it. Doesn't always work of course, but it has for me on a few occasions.<br><br>------>#1 - JD's Trivia game<br><br>------>#2 - MM-MCF Trivia game
Just an FYI Safe Mode first runs Disk Utility on the boot drive only, if it can't fix the boot drive after 2 attempts it will shut the computer down. It turns off all non-Apple startup items and extensions, it turns off all log in items, and clears Font caches.<br><br><br><br>------>#1 - JD's Trivia game<br><br>------>#2 - MM-MCF Trivia game
No, not all, but there is several songs on it. <br><br>What "old references" are you talking about? I want to make sure I delete the right thing.<br><br><br><br>my photos
After running all night by itself, this is what Data Rescue II shows me:<br><br><br><br><br><br>Which is the same thing I saw before I went to bed. crap.<br><br><br><br>my photos
<blockquote><font size=1>In reply to:</font><hr><p>you can delete the old references out of the library and when you connect the iPod it will say that you have purchased songs on your iPod that are NOT in your library and it will ask to transfer them over.<p><hr></blockquote><p>Cool, thanks for that info, didn't know that.<br><br>------>#1 - JD's Trivia game<br><br>------>#2 - MM-MCF Trivia game
Looking back I hope I didn't sound like a smart ass, I was in a hurry and didn't go into much detail.<br><br><br><br>------>#1 - JD's Trivia game<br><br>------>#2 - MM-MCF Trivia game
Re: grey buttons. I was just wonderiong how you got DiskWarrior to give the error if it didn't start checking the disk after you clicked the Rebuild button.<br><br>Re: DataRescue running all night, doesn't look good.<br><br>By references I believe Zach means songs, podcasts, video, etc.<br><br>Zach trying to act all technical and stuff. <br><br>------>#1 - JD's Trivia game<br><br>------>#2 - MM-MCF Trivia game
