Hmmm...interesting. Yes, CRW is Canon's version of RAW.<br><br>What version of Photoshop do you have? If you want, you can email me the files and I can try to convert if you want.<br><br>my photos
I have Photoshop version 7.0.<br><br>I have about 50 to convert- I think it'd cause you lots of grief and time... I appreciate the offer though.<br><br>David (OFI)
I repeat;<br><br>"Copy them from the Canon to the computer then drag them into iPhoto maybe."<br><br>In this case it's from the card.<br><br><br>------> JD's Trivia game<br><br>------> MCF-MM Trivia game
Reboot OSX and MacB .... yeah my Photoshop -s Pre- historic !! <br><br>I'm going to try a trial Aperture... for 30 days... I may have accidently switched the mode in the camera. the ones I can import are jpg ! ... so I think I screwed up somewhere !!<br><br>I tried your method Reboot - iPhoto says it can't read them "error".<br><br>David (OFI)
#351893 - 03/19/0807:10 PMRe: iPhoto- Camera problem
[Re: DLC]
Which iPhoto version do you have? '08 should be able to handle those raw files. raw files are not compressed, right? I know that folks who rely on photography for a living prefer working with raw files, don't they?<br><br><br>
<blockquote><font size=1>In reply to:</font><hr><p>raw files are not compressed, right?<p><hr></blockquote><p>Raw files are compressed, but not processed in the camera like jpegs.<br><br>Old farts, the hidden caulk of civilization. Jim Atkinson<br><br>
Sumpin's funny. iPhoto 5 could do RAW I thought.<br><br>Format the card if it doesn't clear up. I format mine using the camera every time after I Import into iPhoto.<br><br>------> JD's Trivia game<br><br>------> MCF-MM Trivia game
Hi everyone... I checked the camera compatibility of iPhoto 08 and it only will import Raw from Canon G5 - G9s ... mine is an old G2 <br>I'll tell ya every exception to the current rules- I fit ! <br>This weekend I'm going to try the trial Aperture- it's supposed to import raw... <br>Canon doesn't even support the raw image importer for my camera any more... <br>I'm screwed if Aperture doesn't work. <br><br>Guess time to consider a newer and better camera... the G9 looks nice. <br><br>David (OFI)
