Flying pointer #351734 03/17/08 04:31 PM
D
danszyk Offline OP
stranger
stranger
D
I have a 1.8 G5 MacPro......since I loaded Leopard my cursor(pointer) will eradically jump to the corners of my desktop....what could be wrong/resolution to this problems. Your response would be greatly appreciated.<br>Dan<br><br>
Re: Flying pointer [Re: danszyk] #351735 03/17/08 10:53 PM
A
Anonymous
Anonymous
A
What kind of mouse are you using? If it is a standard-issue Apple USB mouse, is it on a shiny surface? <br><br>
Re: Flying pointer [Re: ] #351736 03/18/08 04:01 PM
D
danszyk Offline OP
stranger
stranger
D
I am using the standard Apple mouse on a shiny surface.....but it never reacted like this in the past. It started to jump only after installing OS 10.5. It has become a nuisance during standard operation.<br><br>
Re: Flying pointer [Re: danszyk] #351737 03/18/08 04:05 PM
Reboot Online Content
Online Content
Is the mouse going bad? When the wire going into the mouse starts to break it does that. Bad design, they all do that. Can you try it on a different computer or try a different mouse?<br><br>------> JD's Trivia game<br><br>------> MCF-MM Trivia game
Re: Flying pointer [Re: danszyk] #351738 03/19/08 12:50 AM
A
Anonymous
Anonymous
A
Check out this link, if this is the mouse you're using. It shows how to repair it.<br><br>Edit, of course, trying a different mouse would be a heck of a lot easier! <br><P ID="edit"><FONT SIZE=-1><EM>Edited by dreed2 on 03/18/08 08:53 PM (server time).</EM></FONT></P>
