Pete
www.workwithpete.com
Loc: United States
Well you could always visit a CompUSA and get your whopping 5% (or is it 5?) off of that. <br><br><br><br>[color:purple]Work With ____! </font color=purple>
Chances are your Linksys works great. Like I said most I have set up do. But I have set up three that did not work in the environment I set them up in. The first two the wireless did not work for Internet, you could connect to the router, share files, but no surfing. I went back and got replacements, which didn't help, another brand fixed it though. I was drawn by the low price. The third one that didn't work did not want to work in a shop that had some legacy ethernet equipment mixed in, it wasn't a wireless. Things would work with an older Linksys I carry as a test router for trouble shooting, a replacement Linksys/Cisco didn't work either, but a new one of another brand fixed it.<br><br>As usual YMMV, but I have never had those troubles with any other router brand and I've set up just about every brand out there.<br><br>------> JD's Trivia game<br><br>------> MCF-MM Trivia game
Loc: In Your Servers
Linksys does not like you Reboot <br>I have used Linksys for several years with out any problems however all my Linksys routers are dormat now after I went FIOS I now use the Apple wireless N router<br><br> My Ultimate Amazing Crap !
Will they accept my BB gift card?<br><br>NO !<br>Just send me the card and I will call Best Buy and tell them that your on the way<br><br> My Ultimate Amazing Crap !
An Express would work for me, except I'm still using a 2nd gen G4 (mucho modified) without an Airport card (can't get 1st gen cards anymore for cheap - besides, 1st gen wireless is way slow) so I need wired ethernet ports also. Do the USB 2.0/wireless converters work worth a damm?<br><br><br>
Personally I would stay away from USB when it comes to internet connectivity unless it was a laptop without a built-in card.<br>Get a real router with four ports wireless or not wireless<br><br> My Ultimate Amazing Crap !
D-Link ordered (looks just like my wired D-Link which has worked flawlessly). Yeah, I'll save up for a MacBook for sometime later this year (or maybe a mini for myself, but I'd rather go mobile I think). My G4 FrankenMac just keeps on going and going and going.... <br><br><br>
