You have CS? That's what I have.<br><br>You can convert the NEF files to dng files if you want but the Adobe Camera Raw converter should do it.<br><br>
[white]I'm also known as OSXaddict[/white]<br>
garyW
mid-century modern
Converting to .dng (Adobe DNG convertor) allowed it to open in RAW and then saved as tif. Thanks for that!<br><br>None of the other recommendations worked, the .NEF file could not be recognized as an item to select, or else it only opened the very low res pict preview of the file.<br><br><br><br>
What on earth is a 'bunt' cake?<br><br>- padmavyuha (in merrie Engelande)<br><br>[color:purple]A lopsided man runs best along the little side-hills of success<br>- Frank Moore Colby</font color=purple>
