Well I stand corrected. I used to be able to convert it to MP3 - I dunno when/how it changed. That being said, the ole burn to disc image does still work as it creates an .aiff file which of course can't contain a DRM.<br><br>CreativeGuy for daily tips, tricks and commentary on all things graphic design.
#302515 - 01/19/0702:32 AMRe: apple to open up DRM in iTunes
[Re: yoyo52]
trey Custom Title (50 characters max)
Loc: The Wizard's Balcony
That's likely becuase you haven't allowed Toast to update. There was an update -- I won't even attempt to guess which -- to Toast 6 that disabled the ability to use iTMS protected content.<br><br>And there's always jHymn.<br><br>
Bah! I just wasn't meant to use the iTMS. It knows I hate it and is thwarting my every move to remove its diseased code.<br><br>I can only assume this means that it doesn't run on Intel Macs. It won't even load.<br><br><br><br><br>
#302522 - 01/19/0704:26 AMRe: apple to open up DRM in iTunes
[Re: Trog]
Yeah, it's probably not universal. But it sure does work, I'm stripping the DRM off of some reggae albums <s>for a friend</s> to put in my archive.<br><br><br><br>
