#297692 - 11/28/0612:59 PMNeed help expanding my home network...
G4Dualie
I invented modding!
Loc: Yuba City, California
The image below represents my current setup, which consists of a cable modem and a router. Both bedroom computers are connected to the internet, however, I would like to add my xbox 360 to the mix.<br><br>I don't have the inclination to dig up the carpet in order to lay down another ethernet cable, nor is wireless an option right now. I do have a hub that I was hoping to use to provide the xbox and computer access points to the Net. Is this doable? I can't seem to get it to work.<br><br>The ethernet cable coming into Bedroom #2 does provide access to the router and I have been trying to connect that cable to Port #8 on the Hub. When the Cascade Switch is set to Crossover, I get what appears to be a collision-free signal and the lights on the face of the Hub are green. I connected the computer and xbox to Ports 1 and 2 on the Hub but neither can access the internet.<br><br>Does the TCP/IP and DHCP configuration require some advanced settings besides what the Internet Assistant can do to connect me otherwise?<br><br><br><br><br>M i c h a e l (OFI)
Why not run the router to bedroom #2 instead of that hub?<br><br>Since you have an ethernet wire running from living room to bedroom #2, replace that hub with the router and run the bedroom #1 wire to the router.<br><br>Edit:<br>oh...re-read your post and see that you don't want to run wires, which means you don't want to run cable wire either.<br><br>Perhaps the ports on the hub or router need to be opened? I haven't a clue.<P ID="edit"><FONT SIZE=-1><EM>Edited by OSXaddict on 11/28/06 05:28 PM (server time).</EM></FONT></P>
#297694 - 11/28/0602:35 PMRe: Need help expanding my home network...
[Re: G4Dualie]
MikeSellers
I'm not into titles
Loc: Alpharetta, GA
I've had a setup like this before and it should work without changing any settings on the computer. Sounds like the hub may be the problem. I'd try an ethernet switch instead.<br><br>
#297696 - 11/28/0603:14 PMRe: Need help expanding my home network...
[Re: MikeSellers]
G4Dualie
I invented modding!
I had this set up working once before. I used the Hub to add my LaserWriter to an existing network. I just can't remember the proper configuration of cables and switches.<br><br>I'll look into the Linksys switch John is talking about.<br><br><br>M i c h a e l (OFI)
If you connect the cable from the router directly to the computer and/or xbox in Bedroom #2 do you get Internet access?<br><br>BTW hub =switch, same thing.<br><br>
#297698 - 11/29/0609:00 PMRe: Need help expanding my home network...
[Re: Jim_]
G4Dualie
I invented modding!
Yes, but if I have to, I will unplug the internet connection from the computer and plug it into the xbox when I want to use xbox live.<br><br>I was hoping that I could somehow use the hub as a kind of splitter so I could... well... you know what I mean.<br><br><br>M i c h a e l (OFI)
I know what you mean. It should be working the way you have it wired.<br><br>As far as connecting direct, I was wondering if it actually did work that way. It's supposed to, wondering if it's a cabling problem, or a bad switch.<br><br>
#297700 - 11/29/0611:14 PMRe: Need help expanding my home network...
[Re: Jim_]
G4Dualie
I invented modding!
I'm thinking my hub is bad. I double-checked the Belkin Router manual and it states I can attach a hub directly to the router via the Uplink ports on both devices with a straight-through cat-5 cable.<br><br>So I'm going to buy the Linksys hub John recommended.<br><br><br>M i c h a e l (OFI)
