Hi all..<br>Is anyone using MacMPEG2Decoder b3 ????<br>Im running 9.2 on a Ti667 and everytime I decode a mpeg 2 file usinf MacMPEG2Decoder b3 the .mov it creates is 100 frames per second... which is way too much. OK, I can re-render the movie in Final Cut Pro or Qicktime pro etc, but its a rendering process that I can really do without. Has anyone else had this problem, and if so, did they find a solution?<br><br>
