....when you're importing tracks into itunes, how do you keep it from importing duplicates?<br><br>I thought it used to ask, but no such luck. <br><br>
I don't remember it ever asking... but if you leave this unchecked it won't duplicate.<br><br><br><br><br><br><br>edit:<br><br>I just realized that's probably not what you're talking about. You mean two of the same track in your library? There are some Applescripts for removing dupes.<P ID="edit"><FONT SIZE=-1><EM>Edited by Trog on 08/12/06 07:37 PM (server time).</EM></FONT></P>
Right..two of the same tracks in the library...I somehow thought that it would ask you, as you were importing it, if you wanted to copy over duplicate tracks. <br><br>Maybe I'm thinking of iPhoto, which I know does that. <br><br>
How are you importing it? If I drag a song into my library that is already imported nothing happens (i.e. I don't get a dupe). <br><br>I imagine if I moved the file to another directory it would probably import it as a dupe, but I don't know how iTunes (or iPhoto) would know that two files in different locations are the same thing (especially with different time stamps, etc.)? Are you sure iPhoto can do this?<br><br>
I'm importing it by dragging it into the library window in iTunes. <br><br>iPhoto asks you if you want to import a duplicate photo. I'm assuming it just goes based on the file name or exif info or whatever. Here it is...and this is what iTunes needs:<br><br><img src=http://bellsouthpwp2.net/f/i/filelocker/iphoto.jpg> <br><br>
And in order for iTunes to recognize a duplicate, the tracks must be the same name and length, otherwise iTunes thinks it's a different track.<br><br>CreativeGuy for daily tips, tricks and commentary on all things graphic design.
<blockquote><font size=1>In reply to:</font><hr><p>the tracks must be the same name and length<p><hr></blockquote><p>and same ID3 information too I believe.<br><br><br><br>Hey I'm an F'n Jerk!<
#283948 - 02/13/0709:01 PMRe: How do you....
[Re: Bryan]
lanovami This space for rent
Loc: 東京都
Hey Bryan. Good to see you are still among the living. It seems I remember iTunes used to ask about duplicates when I imported as well...strange.<br><br>We are what we repeatedly do. -Aristotle
_________________________ We are what we repeatedly do - Aristotle
