I am trying to use my iDisk for the first time, but it doesn't let me synchronize it with the .mac account (ERROR 12). After having created the copy of the idisk it keeps telling me that in order to finish the initial installation I have to go online with .mac and my password. I don't understand what it means (I have been online all the time...!) Anybody has a solution?<br><br>
Thanks for the answer, I had done it and it doesn't change the fact that the sync won't start. "You cannot sync at this time (error 12)" I am using OS 10.3.9.<br><br>
#253192 - 10/26/0508:10 AMRe: idisk initial problem
[Re: macidiot]
Lori
missing in action
Loc: Ct, USA
In your System Preferences/Internet and Network/idisk:<br>-make sure all info is there under the account tab<br>-under the idisk tab make sure you have clicked the "start" button, and set it to automatically sync<br><br>If you have done all this and still get the error message, then they could be having server problems at this time (it does happen)<br><br>I've got to tell you, I used to have a copy of my idisk on my computer and sync it.<br>I don't anymore, it's too much trouble. I can quickly mount my idisk and copy files to it and know that they are uploaded on the spot.<br><br><br>For Mike
#253194 - 10/26/0511:51 AMRe: idisk initial problem
[Re: macidiot]
steveg
Making a new reply.
Loc: D'OHio
iDisk syncing has been pretty unsatisactory for months now. I finally gave up and trashed the local copy, and when I need to upload a file, I just mount my iDisk manually via the "Go" menu, copy my files over, and eject the iDisck when I'm done. Even then, performance can be sluggish, but at least you're not being plagued by sync errors.<br><br>
#253195 - 10/26/0501:38 PMRe: idisk initial problem
[Re: steveg]
Michael
Loc: Foxwoods
I don't believe you even need to go to the go menu. Just open a finder window and the iDisk icon will be in the left column. You can access it from there and it will also mount on the desktop.<br><br>
