• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » General Discussion » Stan's Lounge » Anyone over here know video compression?
Page 1 of 2 1 2 >
Topic Options
Hop to:
#252584 - 10/22/05 03:46 PM Anyone over here know video compression?
zwei Offline
soporific
OK ...I have quite a few home movies that I have saved on my HD as full-quality DV files. In short, I want to know what the best way to compress them to conserve space, but retain really high quality. First off, I'm not looking to use H.264. I have decided I want to use MPEG4-Improved for several reasons. <br><br>1. It encodes about a bazillion times faster than h.264. <br>2. I can import them into MP4 iMovie projects without having to wait for them to be converted again. (biggest reason) <br><br>If I use MPEG4-Improved, what are the best settings to keep the file as close to the original as possible, but still be worth compressing. I've looked all over the web for data rates, but can only seem to find them for h.264 ...which says a good data rate for 640x480 is between 1000-2000kbps ...what is a good rate for MPEG4-Improved? When I click around in the QT boxes a number of 6400kbps pops up in the bitrate field. I googled it and found that MPEG2 at 6400kbps is DVD quality ...what would be the equivalent of that in MPEG4?<br><br>Also, are there any lossless codecs in the list? If so, I may be interested in using that instead. <br><br>I also tried Apple Pixlet ...wasn't impressed with the results. <br><br>Thanks for any help!<br><br>
twitter
Top
#252585 - 10/22/05 05:38 PM Re: Anyone over here know video compression? [Re: zwei]
Papa Offline
In Vegas with Nina Agdal
You can switch but you can't hide.<br><br>I am supposed to call a guy at 2pm to see if I can find the answer.<br><br>
Common sense and deodorant are a lot alike. People who need it the most don't use it.
Top
#252586 - 10/22/05 05:46 PM Re: Anyone over here know video compression? [Re: Papa]
zwei Offline
soporific
haha ...I've been found out! <br><br>
twitter
Top
#252587 - 10/22/05 07:58 PM Re: Anyone over here know video compression? [Re: zwei]
Papa Offline
The phone call didn't provide an answer. I didn't have much luck with a google search either. <br><br>
Top
#252588 - 10/22/05 08:29 PM Re: Anyone over here know video compression? [Re: zwei]
Michael Offline
Loc: Foxwoods
I've had good results with FFMpegX, but you can test the different options for quality and output size with any app. In QT just select and cut 1 min. of video. Open a new QT window and paste. Then export that to DV stream. You can then test any of your settings with that 1 min DV file.<br><br>
Top
#252589 - 10/22/05 09:16 PM Re: Anyone over here know video compression? [Re: Michael]
zwei Offline
soporific
I've been looking around apple discussions too, apparently the MPEG4 support was screwed up a bit by QT 7.0.3 ...I have exported a couple of my DV files at 6400kbps with automatic keyframs. The quality looks great to me, but I get jerky playback (sometimes HORRIBLE) on my 733. Apparently QT 7.0.3 has had that affect on several users.<br><br>
twitter
Top
#252590 - 10/23/05 03:08 AM Re: Anyone over here know video compression? [Re: zwei]
ezyrider Offline
old hand
Loc: Dallas, Texas
MPEG 4 is the cheapest and best quality (QT Pro $30). Or just plain MPEG (I have the Apple MPEG2 component in OT Pro - $20). Otherwise I use Sorenson Pro (expensive at $299 but worth it, better quality than MPG4). <br><br>
Top
#252591 - 10/23/05 05:27 AM Re: Anyone over here know video compression? [Re: ezyrider]
zwei Offline
soporific
So what data rate for MPEG4 would you suggest? At 640x480 keeping quality really high.<br><br>
twitter
Top
#252592 - 10/24/05 04:02 AM Re: Anyone over here know video compression? [Re: zwei]
Topper Offline
Loc: Massachusetts
I mostly work with DVPRO50 and Blackmagic DV codecs.<br>I also use Sorenson Video 3 and MPEG-4.<br>My preference for MPEG-4 is 2000 kbps. <br>It isn't anything that I read about. I took most of the QuickTime codecs and made tests with each of them. The 2000 kbps looked good while keeping a fairly small file (at least when compared to DV codecs).<br>I am not sure what you mean by "are there any lossless codecs in the list?"<br>Do you mean MPEG-4 lossless codecs? If so, I haven't heard of any.<br>As I am sure you know with any lossless codec you will pay the price in file size and I thought that was what you are trying to avoid.<br>Otherwise Apple, Blackmagic, and Aurora have excellent lossless DV codecs<br><br>
Top
#252593 - 10/24/05 05:00 PM Re: Anyone over here know video compression? [Re: Topper]
zwei Offline
soporific
Thanks for the reply ...i have settled on the following settings.<br><br>MPEG4-Improved, 3500kbps, Keyframe every 30, 128AAC audio/best<br><br>For some reason when I tested at 3500kbps before it looked rather crappy ...but I found out it was because I set the keyframes to auto. I figured Auto was best, but apparently not! <br><br>
twitter
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek, MacGizmo, Moderator, neil, Reboot
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.057 seconds in which 0.039 seconds were spent on a total of 14 queries. Zlib compression enabled.
