I just recently purchased a powerbook. I have a lot of music files on a PC to transfer. At first I was trying to do that via network, but that is complicated and tricky. I was planning on getting an Ipod and trying to tranfer the files that way.<br>Is this possiblem, and how is it done?<br><br>
#251390 - 10/14/0510:36 AMRe: Ipod file transfer question...
[Re: bullyblinders]
Pete
www.workwithpete.com
Loc: United States
Are you talking about using your iPod as a FireWire disk and transferring the files that way?<br><br>If so, just make sure you check the 'Enable Disk Use' under your iPod prefs in iTunes, and it will appear on the desktop - you should be able to copy anything you like to the iPod and onto another machine...<br><br>Hope that helps...<br><br><br>
Don't get an iPod just for that. You should rather get an Ethernet cable and hook them up. It's not complicated at all.<br><br>creativebits / adsoftheworld
#251393 - 10/15/0508:49 AMRe: Ipod file transfer question...
[Re: garyW]
MacGizmo
Moderator
Loc: Arizona
<blockquote><font size=1>In reply to:</font><hr><p>That will need to be a 'cross-over' ethernet cable, right?<p><hr></blockquote><p><br>If the Mac is newer than 5 years old or so, it won't matter what kind of ethernet cable it is. Apple stopped producing Macs with that requirement a while ago.<br><br>
