#235974 - 06/22/0510:32 AMAnybody using a gMail Dashboard Widget?
SparkCollector
Loc: Lancaster PA USA
When I first got my gMail account a couple weeks ago I tried the little menulet <A HREF=http://www.lloydslounge.org/gee/>[color:TEAL]<U>GEE</U></FONT></A> to automatically check my gMail account for incoming messages, but it kept flaking out on me so I ditched it.<br><br>I decided to have a look for a Dashboard widget to automatically check my gMail account. I chose to try <A HREF=http://sourceforge.net/projects/gotmailg/>[color:TEAL]<U>"gotMailG"</U></FONT></A> (from Sourceforge.net, and listed on Apple's Widgets directory) and haven't been able to get it to work.<br><br>Any thoughts? What's been working for you with your gMail account to automatically check Incoming Mail status?<br><br>
#235976 - 06/22/0511:54 AMRe: Anybody using a gMail Dashboard Widget?
[Re: SparkCollector]
MacGizmo
Moderator
Loc: Arizona
I used Gcount for a while, it worked perfectly. But now I just have Mail to get my GMail.<br><br><br><br>CreativeGuy: For your "fix" of design software tips, tricks & commentary.
#235979 - 06/23/0504:48 PMRe: Anybody using a gMail Dashboard Widget?
[Re: skim1420]
SparkCollector
I have 3 different accounts set up in Thunderbird, Steven.<br><br>Hmm...I never even thought to see if I could set up another account to check on gMail's incoming messages automatically.<br><br>Ummm, do you have any idea if it's possible before I go off and running on a wild goose chase?<br><br>
#235981 - 06/23/0508:49 PMRe: Anybody using a gMail Dashboard Widget?
MacGizmo
Moderator
Loc: Arizona
You can either have thunderbird actually check the Gmail server, or you can have Gmail forward a copy of all mail to another address.<br><br><br><br>CreativeGuy: For your "fix" of design software tips, tricks & commentary.
#235982 - 06/23/0508:54 PMRe: Anybody using a gMail Dashboard Widget?
[Re: MacGizmo]
SparkCollector
I tried for a few minutes and couldn't get the gMail account I set up in Thunderbird (following Google's Windows-centric Help page instructions) to retrieve any test messages.<br><br>I'll futz with it when I have more time and patience.<br><br>
