<blockquote><font size=1>In reply to:</font><hr><p>A backup solution that requires you to type codes into the terminal is hardly a solution<p><hr></blockquote><p>Yep, good point.<br><br><blockquote><font size=1>In reply to:</font><hr><p>Get .Mac - use Backup 2!!!<p><hr></blockquote><p>Now that really costs a lot of $$<br><br>
#227575 - 05/05/0509:38 AMRe: Backing up in Tiger...
[Re: Mississauga]
Pete
www.workwithpete.com
Loc: United States
I use Backup with my LaCie drives - a great replacement for Retrospect.<br><br>Same here- works great for me!<br><br><br>[color:green]5.19.05 - The 'Jedi Slaughter' tour begins!</font color=green>
<blockquote><font size=1>In reply to:</font><hr><p> I'm one of those complete hayseeds...I just copy the files manually!<p><hr></blockquote><p><br>Me too. I figure I need the exercise.<br><br>
Thanks for that link to Synk. I downloaded it and have 29 more days. It works just fine for me. <br><br>I noticed this for the price.<blockquote><font size=1>In reply to:</font><hr><p>As I am a starving student myself, I understand how tight budgets are. As such, single-user licenses of Synk 5 are free to students and faculty of accredited educational institutions. Send me an email from your school email address to receive your registration code.<p><hr></blockquote><p>Does anyone here have a school email account I can borrow for a quick email? <br><br>
#227581 - 05/13/0510:11 AMRe: New version just came out
[Re: RubenC]
RubenC
Artimus Maximus
Loc: Beautiful Southern California
LaCie's free back up program Silverkeeper has been available for a week now<br><a href="http://www.lacie.com/silverkeeper/" target="free" <em> Silverkeeper</em> </a><br><br>
#227582 - 05/26/0509:50 AMRe: Backing up in Tiger...
[Re: hayesk]
Anonymous
psync for me is _not_ backing up extended attributes in Tiger.<br><br>ie. the metadata that spotlight uses is not being copied.<br><br>This is probably because MacOSX::File doesn't know anything about xattr?<br><br>Try it yourself. Add keywords to a photo and then backup the jpeg. mdls will show you the metadata isn't copied to the destination.<br><br><br>
