Gahhh!!! I was just about to install Deja Vu for doing backups now that I have Tiger installed on my G5. I was wondering if it was time for a "what do you use to backup in Tiger?" thread... I guess you beat me to it.<br><br><br><br><br><br>CreativeGuy: For your "fix" of design software tips, tricks & commentary.
#227547 - 05/04/0509:47 AMRe: Backing up in Tiger...
[Re: Trog]
Lori
missing in action
Loc: Ct, USA
I am pretty sure it is not scheduled. I think it is a one time deal, but I don't know.<br>It would suffice until the other apps get updated maybe.<br><br><br>For Mike
#227551 - 05/04/0511:10 AMRe: Backing up in Tiger...
[Re: Trog]
zwei
soporific
Loc: Near an iPad
You can backup via automator ...the only downside is that it will do a full backup every time until someone writes an action to only update changed files.<br><br>
#227552 - 05/04/0511:19 AMRe: Backing up in Tiger...
[Re: zwei]
Lori
missing in action
Loc: Ct, USA
ah come on zach, go ahead and write an action. then you can send it to Apple and be a hero! <br>PS...you know I'm only playing with ya betwen here and MC..ha <br><br><br>For Mike
