#219383 - 03/08/0508:03 AMAnyone have any luck with...
Pete
www.workwithpete.com
Loc: United States
The iPod battery replacement program?<br><br>I think I may be having some problems with mine- didn't hold a charge after what seemed like a whole weekend with the device plugged into my Mac...<br><br>[color:red]MLB, O&A - only on XM! Sign up now and drive up my stock...</font color=red>
#219385 - 03/08/0508:09 AMRe: Anyone have any luck with...
[Re: ]
Pete
Loc: United States
The cheaper route being to buy the battery myself and perform surgery?<br><br>AHAHAHAHAHHAHAHHAHANo.<br><br><br><br><br><br>[color:red]MLB, O&A - only on XM! Sign up now and drive up my stock...</font color=red>
#219386 - 03/08/0508:25 AMRe: Anyone have any luck with...
[Re: Pete]
Why not? You pry it open, plug it in and smash it back together. What do you think the buttnut they pay $4.75/hr. at Apple's repair house is gonna do differently?<br><br>
#219387 - 03/08/0508:45 AMRe: Anyone have any luck with...
[Re: ]
Pete
Loc: United States
Hey, that's not nice...our own Michael used to BE a 'buttnut'.<br><br><br><br>[color:red]MLB, O&A - only on XM! Sign up now and drive up my stock...</font color=red>
#219389 - 03/08/0509:07 AMRe: Anyone have any luck with...
[Re: Pete]
adzoox
member
Loc: Greenville SC
It's VERY easy - ask a local guy to do it for you.<br><br>Buy the Newer Tech high capacity battery - they're awesome<br><br><br><br>WWW.ADZOOX.COM & www.JACKWHISPERS.COM
#219390 - 03/10/0512:07 PMRe: Anyone have any luck with...
[Re: adzoox]
Pete
Loc: United States
Do you have a link to the battery you're referring to? Does it come with a instruction kit perchance? <br><br>I just got off phone with Smalldog and they claim that battery replacement is not that hard at all, and that I should be able to do it myself. So if the higher capacity battery you posted about comes with instructions, I might give it a whirl.<br><br><br>[color:red]MLB, O&A - only on XM! Sign up now and drive up my stock...</font color=red>
#219391 - 03/10/0512:11 PMRe: Anyone have any luck with...
[Re: Pete]
Morom
addict
Loc: Chicago, IL
Well, there is this one if you have a 4G iPod<br><br>http://macminute.com/2005/03/03/newertech-owc/<br><br>That same link also gives you options for other generations of iPod's as well if you don't have the 4G.<br><br>----<br>Stupidity is like nuclear power. It can be used for good or evil.... and you don't want to get any on you.
---- Stupidity is like nuclear power. It can be used for good or evil.... and you don't want to get any on you.
#219392 - 03/10/0512:25 PMRe: Anyone have any luck with...
[Re: Morom]
Pete
Loc: United States
Thanks- I sorta found that link on my own, but that particular site doesn't offer a replacement service. Just don't wanna scratch the hell out of my iPod is all...<br><br>[color:red]MLB, O&A - only on XM! Sign up now and drive up my stock...</font color=red>
