I followed the help and set up everything correctly, but Mail just doesn't want to start downloading the gMail. Also, what I find weird is that in the gMail settings/Forwarding and POP I switch on the radio button which says: Enable POP for all mail (even mail that's already been downloaded) and save the changes, but when i return to these settings, none of the three radio buttons are selected? Any help would be appreciated.<br><br>
That's it. If you go back to it, none of the buttons will be pushed, but it will say above it that it is been enabled. <br><br>Also, I'm sending and receiving e-mail through Mozilla with Gmail just fine, using their server both ways. I also have my Panther Firewall full up. Looks like there's no issue after all. <br>
#217208 - 02/17/0501:16 PMRe: Did you manage to set-up gMail POP on Mail.app?
[Re: iraszl]
zwei
soporific
Loc: Near an iPad
I have mine working just fine. When you set it up via mail pay close attention to the port numbers. ...and make sure you have the SSL connection checked.<br><br>
