• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mac » Software » Safari and "localized string not found" fix
Page 1 of 2 1 2 >
Topic Options
Hop to:
#191165 - 09/12/04 07:00 AM Safari and "localized string not found" fix
G4Dualie Offline
I invented modding!
Loc: Yuba City, California
I don't know if any of you are still having issues with the "localized string" with your contextual menus but I've found a fix that is solid. If anyone is interested, though it takes a Restart, the whole process takes a few minutes to accomplish.<br><br>1. Download the latest version of Safari from Apple. Found here. This step cannot be ignored.<br><br>2. Locate the webkit files and trash them. This folder is located in System/Library/Frameworks/webkit.framworks.<br><br>3. Install Safari from your download.<br><br>4. Restart the computer.<br><br>5. Launch Disk Utility and run Repair Permissions.<br><br>6. That's it. You won't see the words "localized string not found" appear in your Contextual Menus anymore.<br><br><br>[color:red]I am not John Kerry and I made this ad.</font color=red>
M i c h a e l (OFI)
Top
#191166 - 09/12/04 07:27 AM Re: Safari and "localized string not found" fix [Re: G4Dualie]
iRock Offline
Livin' on the road my friend
Loc: Pacific NW, USA
Thank you so much. That drives me crazy. I am going to try it tomorrow.<br><br>
oh yeah, that's going in the blog
Top
#191167 - 09/12/04 10:08 PM Re: Safari and "localized string not found" fix [Re: G4Dualie]
iRock Offline
That is super! Thanks so much. It is a few steps but not hard. Well worth it. Now after Rick goes to work I will fix his.<br><br>
Top
#191168 - 09/13/04 01:53 PM Re: Safari and "localized string not found" fix [Re: G4Dualie]
hayesk Offline
Loc: Ottawa, Ontario, Canada
Does this happen from using one of those utilities that rips out other language files?<br><br>Localized strings are basically translations of text in an application in a specific language.<br><br>
Top
#191169 - 09/14/04 04:44 AM Re: Safari and "localized string not found" fix [Re: hayesk]
G4Dualie Offline
I invented modding!
If you're referring to one of those utilities that's used to trim the fat in your OS by removing unwanted languages then yes, you're probably right. It makes sense to me anyway. <br><br>However, I never installed the languages to begin with and I believe my "localized" errors began to show up right after I upgraded to Panther and the new Safari (1.1?)<br><br>Anyway, the "localized" annoyance is now gone. <br><br>
M i c h a e l (OFI)
Top
#191170 - 11/10/04 08:57 AM Re: Safari and "localized string not found" fix [Re: G4Dualie]
Anonymous
Yikes! I tried this method of removing the dreaded "localized string not found" using the steps in your post. Now, Safari won't even open. Went through the whole proceedure again & still no luck.<br><br>The WebKit file now shows up as an alias. It has no original (removed earlier) and can't be deleted. Is this method supposed to create a new WebKit file? <br><br>I'm running 10.3.6 and downloaded the lastest Safari as per your post.<br><br>I'm stuck. any ideas?<br><br>Thanks,<br>Ideo<br><br>
Top
#191171 - 11/27/04 06:14 PM Re: Safari and "localized string not found" fix [Re: G4Dualie]
globewriter Offline
stranger
Loc: Toronto, Canada.
Thanks for the advice. I managed to prevent my mac from starting...I sytupidly used Deinstaller and uninstalled Safari..apparently it is completely integrated into Panther. First my Finder went funny..then stopped..and rebooting resullted in just the gray firmware screen...spinning away. <br><br>Anyhow..I reinstalled Safari ( smart of me to have an external boootable drive) but now I notice that it is v 1.2 Not 1.2.4 like I had before. Did anyone else notice this too? This is the second time I have reinstalled Safari ( the normal way the first time) and got 1.2..apparently the only way to get 1.2.4 is to reinstall panther and do all the upgrades. Software update doesn't seem to bother updating from 1.2 when Safari is installed from Apple's web site. On the other hand...no "localized string message" and I don't see any difference whatsoever..so I suppose "who cares"?<br><br><br>
Top
#191172 - 01/26/05 01:18 AM Re: Safari and "localized string not found" fix [Re: G4Dualie]
Anonymous
It works. sure enough. <br><br>its worth mentioning though, that link does NOT have the latest safari version. It actually installs and older version. <br><br>I had version 1.2.4<br><br>now I have 1.2 (v125). <br><br>software update wont let me get my 1.2.4 back either. :(<br><br>
Top
#191173 - 04/11/05 04:11 PM Re: Safari and "localized string not found" fix [Re: G4Dualie]
Anonymous
Thanks, it did wonders ! Finally rid of this horrible "localized string not found" bug ! I actually trashed the files located in the "version" folder of the webkit.framworks folder - did not hence have the issue of the alias.<br><br>what a relief... this thing was driving me mad !<br><br>
Top
#191174 - 12/22/05 08:05 AM Re: Safari and "localized string not found" fix
G4Dualie Offline
I invented modding!
Merry Christmas! <br><br><br>M i c h a e l (OFI)<br><br>[color:red]"Freedom's untidy. And free people are free to commit mistakes, and to commit crimes and do bad things." — Donald Rumsfeld</font color=red>
M i c h a e l (OFI)
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.118 seconds in which 0.090 seconds were spent on a total of 14 queries. Zlib compression enabled.
