can anyone help--- sherlock 2 on my G4 operates properly ,but when trying to find the application sherlock.I cant find it sherlock says it is in syserm folder but it is not there also not in application folder. nor can I find it in extensions. I wanted to modify it but cant find it, even though it works fine. thanks <br><br><br><br><br>
johnengler
old hand
Loc: Cowtown, Texas
Is it in your "apple menu" folder?<br><br>***<br>"The heart of the wise inclines to the right, but the heart of the fool to the left." <br> -- Ecclesiastes 10:2
TreeBeard
yeah, unless it was manually moved... that is where the Mac OS installer puts Sherlock... <br>in System Folder : Apple Menu Items Folder.<br><br>=============================================================<br>| "Behold the Turtle, he maketh no progress ==== until he sticketh out his neck." |<br>=============================================================
I just had to reinstall everything after I wiped my HD (a sad story), and the OS installed Sherlock 2 in the Applications Folder. There's an alias of it in the Apple Menu Folder, though.<br><br>And that's true too.--Shakespeare, King Lear
TreeBeard
yeah that is true too.. it was once tha Apple extra's folder but always with an alias in apple menu items folder.<br><br>=============================================================<br>| "Behold the Turtle, he maketh no progress ==== until he sticketh out his neck." |<br>=============================================================
#1699 - 07/01/0101:33 AMRe: sherlock
[Re: TreeBeard]
Anonymous
Remember that if using IE5 the Sherlock App must be in the Apple Menu Items Folder.<br>That way the sherlock icon will work in IE5s toolbar...........<br><br>An alias in the Apple Menu won't do it!<br><br>[color:green]The Home Page[color:green]
johnengler
old hand
Loc: Cowtown, Texas
darkstranger... welcome to the boards... <br><br>John<br><br>***<br>"I know God won't give me anything I can't handle. I just wish He didn't trust me so much." --Mother Teresa
Anyone know a hack for this? I wanted to rename "Sherlock" to " Sherlock " (space before & after) and IE5 couldn't find it of course...<br><br>Why would you want to do that?<br><br><br>Hi guys <br><br><br>[color:green]The Home Page[color:green]
