Is there a way I can transfer the music on my iPod (and Mac), onto my PC which also has iTunes on it, without configuring the iPod to just work with the PC?<br><br><br><br>
If I'm correct, I think the iPod can only work with iTunes on one platform or the other...<br><br>If you format it for the PC, I believe you can use it as a FW HD for both platforms, but not on the PC if it's formatted for the Mac...<br><br>That's just what I learned from bits n' pieces of posts on MM...<br><br>[color:red]You slap my back, I'll slap yours!</font color=red>
