<br>In apple Motion, there is a feature called Dashboards(http://www.apple.com/motion/workflow.html). ALso, in addressbook, you can see at full screen somebody's phone number and panic stattoo tattoos info in the screen using capsules.<br><br>is there a framework in xcode for adding that stuff (dashboards or floating semi-transparente dialog boxes) into our apps? <br><br>%-) <--- me?
---- :) "In my experience, there's no such thing as luck." - Obi-Wan Kenobi
