My 12" PB has an airport extreme card. My Quicksilver G4 has a regular airport card. My kid's eMac has an extreme card, and my ex's FP iMac has a regular card. Both base stations are extreme. So how come only my Quicksilver doesn't display the "Use Interference Robustness" option in the airpoirt menu? And WTF is Interference Robustness anyway? <br><br>
<blockquote><font size=1>In reply to:</font><hr><p>And WTF is Interference Robustness anyway?<p><hr></blockquote><p><br>Sheesh! You live in NY City and you don't know what Interference Robustness is?! Dincha ever see King Kong?<br><br>
Lori
missing in action
Loc: Ct, USA
<blockquote><font size=1>In reply to:</font><hr><p>Minimizing interference in an AirPort network<br><br> <br><br><br>You may experience network performance problems if a microwave oven or other source of interference is used frequently near your base station. To minimize interference, turn on interference robustness.<br><br><br><br>1.<br><br>Open AirPort Admin Utility, located in Applications/Utilities.<br><br><br>2.<br><br>Select your base station and click Configure. Enter the base station password if necessary.<br><br><br>3.<br><br>Click Show All Settings, and then click AirPort.<br><br><br>4.<br><br>Click Wireless Options and select the "Enable interference robustness" checkbox.<br><br><br>Client computers with AirPort Extreme cards must choose Use Interference Robustness from the AirPort status menu in the menu bar in order to take advantage of this feature. Client computers with earlier AirPort Cards will already take advantage of the feature.<br><br>The farther away the interference source, the less likely it is to cause a problem.<br><br>For a list of potential sources of interference, see the document "Designing AirPort Extreme Networks" located at www.apple.com/airport.<p><hr></blockquote><p><br>My Stuff
Thanks, Lori. What's odd though is that I'm certain my ex's iMac shows that option in the pull-down menu, even though her iMac is pre-Extreme. Will have to check that out on my next visit to Florida.<br><br>
