#154689 - 04/01/0402:04 PMRe: Okay, one more...
[Re: skuldugary]
For that you'll need a hack. Apple doesn't want you messing with it, since they can't handle support calls in which the user's font size is off by a point. (And forget about doubling the number of mouse buttons!)<br><br><br><br>
