Is there a utility that mimics OS9's pop up windows? I don't mean a boring alias-holding app like DragStrip or DropDrawers. And the Dock doesn't cut it; it has to snap shut when I'm done with it... it has to anchor to the edge of the screen.<br><br>Another useful feature from OS9.... gone. <br><br>
Morom
addict
Loc: Chicago, IL
Is this what you are looking for? Unfortunatly it's still in alpha release though...<br><br>PopUpX<br><br>----<br>A computer without a Microsoft operating system is like a dog without bricks tied to its head.
---- Stupidity is like nuclear power. It can be used for good or evil.... and you don't want to get any on you.
Ewww. That wasn't pretty.<br><br>I want my popup windows back! WAAAAH WAAAAH! I'm so glad Apple spent time on that InkWell crap, aren't you? I use it all the time.<br><br>
"I know one, its called Classic"<br><br>Nah, can't handle the transparent interface and lightning fast response. I need shadows and bouncy things killing my resources instead. <br><br>
Yeah, DragThing is really the only app I've found that comes close. I especially like the default sounds it makes when the docks slides open and shut. But it's really not what he's looking for since you can't have a window's contents be in the dock... just the containing folder, which requires a click and hold to view.<br><br>What?
