Can I have two Macs, connected to the same external Firewire drive at the same time. <br><br>Seems like an easy way to create a drop box between the two. Haven't tried it yet... any thoughts?<br><br>-----<br>Folding for Fun teammacosx dot org
trey
Loc: The Wizard's Balcony
I should think that even if it's just hooked up to one machine that it would still be visible to the other over the network... Of course, I just realized that you may not have a network set up.<br><br>
Yes, I do have an ethernet network, and file sharing. Just seems to be a few steps involved, to quickly transfer a file between two boxes. So I was looking at this firewire drive of mine, and it seemed like this would be a way to have a drop box between the two boxes (photos, one box does the scanning, "a slow process" while the other box can be busy at the photoshop) And at the same time I could stiffen up the firewall, by not allowing things like file sharing or the sorts... <br><br>I'm sure there are also other ways to do this, open to suggestions, thanks<br><br>-----<br>Folding for Fun teammacosx dot org
charlie
newbie
Loc: Barcelona
If that doesn't work you could try IP over FireWire to connect the machines together. Than you have no slow transfers for your big files.<br><br>Add in Teleport from on version tracker and you can take your mouse cursor off one screen and over to the other, and the keyboard too, making your scan and edit on 2 machines easy.<br><br>
