this is the URL of where that particular photo is placed:<br><br>http://homepage.mac.com/asammak/.Pictures/Photo Album Pictures/2002-06-06 17.02.33 -0700/Head-2.jpg<br><br>The spaces might be throwing it off for some browsers, but it works in mine... he just didn't copy the rest of the URL, he stopped at "...Hea" instead of "...Head-2.jpg". See, it works for me, even with the spaces.<br><br>And yes, he does need the whole URL because that's where the photo is located.<br><br><br>[color:red]semicolon dash parenthesis</font color=red>
greenme1
Loc: Pittsburgh, PA
I put:<br>http://homepage.mac.com/asammak/.Pictures/Photo Album Pictures/2002-06-06 17.02.33 -0700/Head-2.jpg <br>into the control panel, it's odd that it would stop at "hea".<br><br>
why don't you take everything out of the box so at least we all don't have to look at a red X box all the time.<br><br><br>[color:red]semicolon dash parenthesis</font color=red>
After the /.Pictures, all you need to do is add the name of the jpg. You don't need the photoalburn stuff. So /.Pictures/Head-2.jpg is good enough. Also, make sure that the capitalization and all is exactly the same as what appears on your iDisk, cause otherwise it won't work.<br><br>Great wits are sure to madness near allied.--John Dryden, "Absalom and Achitophel"
I guess so, but the file is actually in the .Pictures folder/directory, isn' it? At least, that's the way I get images up on any site, but giving the /username/.Pictures/imagename.jpg address and nothing more.<br><br>Great wits are sure to madness near allied.--John Dryden, "Absalom and Achitophel"
