#11730 - 08/22/0207:24 PMRe: Morrowind for mac?
[Re: Trog]
I'd never heard of it either, so I looked it up with Google. It's an RPG.<br><br>Great wits are sure to madness near allied.--John Dryden, "Absalom and Achitophel"
#11731 - 08/22/0207:37 PMRe: Morrowind for mac?
[Re: Trog]
greenme1
Loc: Pittsburgh, PA
it's an open ended Role Playing Game (RGP). it has some of the best graphics of any game out there and is supposed to be really good, but only for the x-box and PC. <br><br>
#11734 - 08/22/0207:49 PMRe: Morrowind for mac?
[Re: greenme1]
I couldn't find the particular post you're referring to, but my rule of thumb is that if people are nasty, they aren't worth the aggravation. And I guess that goes for the game as well.<br><br>By the way, if you want to do a clickable url, you need to put tags around the address. Use the square brackets ([) and (]) to enclose the term url and then again after you've pasted the address, to enclose the term /url. You can get fancy and do url=http://www.elderscrolls.com/ubbthreads/showthreaded.php?Cat=&Board=UBB1&Number=69662 in the first set of brackets, then type the name of the site before you end the tag. Like this, but with square brackets rather than {<br><br>{url=http://www.elderscrolls.com/ubbthreads/showthreaded.php?Cat=&Board=UBB1&Number=69662}game site{/url}<br><br>That will make the phrase "game site" clickable and the reader won't have to suffer with the nasty length of the address.<br><br>Great wits are sure to madness near allied.--John Dryden, "Absalom and Achitophel"
#11736 - 08/22/0208:20 PMRe: Morrowind for mac?
[Re: greenme1]
Have you ever done any of the battle.net games? My son spends hours on battle.net, either with Diablo 2 or with StarCraft. He'd like to get into the WarCraft III stuff, but WC is really creaky on his iBook. I've tried to play all those games, but I'm just lousy at them.<br><br>Great wits are sure to madness near allied.--John Dryden, "Absalom and Achitophel"
